Hello
I recently bought and successfully configured a Cisco UC320W to my small office, and everything's doing well, apart from the SIP account that I intended to use, with Voipbuster.
When I configured the gateway, the SIP account showed up as being registered, and I made a test-call to that VoipBuster account, and I was correctly informed by voice that I had no money in my account. So I Thought the account was correctly configured.
Then I wired 10€ to my account, and tried to contact my cellphone, and nothing happens. I get only one dial tone, and then it goes mute. My cellphone never rang.
If anyone is successfully using a voipbuster SIP account, can anyone tell me the correct settings for that SIP account to work?
This is what i got:
Description: Voipbuster
Proxy: sip.voipbuster.com
Require registration: y
SIP Remote-Party-ID: n
Proxy de saida: <empty>
allow calls from: *
call capacity: 1
place prefix "+35" behind dialed numbers : y
company name: <name>
account ID: <username>
Authentication ID: <username>
password: <password>
SRV: y (i already tried n, with the same result)
SRV prefix: n
NAT: y (already tried without this)
NAT keep-alive: y
Codec: G711U
outgoing fax: pass-through
packet creation sizes: 20 (already tried 30)
NAT Stun Server: stun.voipbuster.com (already tried stun and the local router internet IP address)
local ip address: <ISP IP address>
(I'm using an SMC 7904WBRA2 as a router, already tried forwarding port 5060 to the gateway, and right now I even have a DMZ configures on the gateway local IP address)
Any help will be welcome
