CLI Config for Main number ringing Auto Attendant first
nstcctv01
I am trying to change a config from CLI on a UC560.  The system currently has a PRI with DIDs going direct to extensions and noans & busy going to auto attendant (4702).  The main number is currently going to extension 4710.
I am trying to have the main number 4710 ring direct to auto-attendant 1(4702) then have 4 extensions in a hunt group ring sequentially.
How do I have the DID hit the AA first then have one of the selector code options hit a hunt group? Then how do I configure if no one answers or all are busy then direct to the general voicemail box?
shusarka
Could you please share the running configuration from both UC560 and CUE module.
Command would be : show run
from the CLI of both UC560 and CUE.
Once I have them, I will let you know the details.
Sincerely,
Shubhamoy
Attached is the fiile
How do I access CLI of CUE?  Putty telnet will not work.
