02-21-2012 11:26 PM - edited 03-21-2019 05:23 AM
Hi!
I have discovered, that there are no SPA telephones under the "load" command in "Telephony-service" section.
There are only 6xxx and 7xxx types.
Is there any way to configure SPA telephones in CME 9.0? Or this is only IOS question?
Aleksei
02-21-2012 11:38 PM
HI,
Natively only folloing phones are supported
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html
SPA telephones are not supported, so you will not find any load for them.
They will be added as third party SIP phones only.
Ronak Patel
02-21-2012 11:45 PM
Hmm. I have UC 540 with CME 8.0.
I have found the spa phones under the load command on UC540.
And there are no SPA phones in documentation for CME 8.0 also.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme80spc.htm
So I think there is some other reason.
By the way, how can I configure SPA telephone, which requires configuration and firmware from the CME, if consider that SPA is now third party?
02-22-2012 12:51 AM
See if this helps you for the configuration.
Ronak Patel
02-22-2012 11:01 AM
SPA phones use SPCP protocol. It is like a crippled version of SCCP/skinny. Presumably, Cisco wants these cheaper phones only to work on UC3XX and UC5XX systems and encourage you to buy more expensive phones for CME and CM..
However as other posters said, you can flash them with SIP firmware and then treat them as third party SIP phones.
However, as third party SIP you should expect some feature deficiencies compared to supported phones.
02-22-2012 11:07 AM
My friend Brandon speaks the Truth here. +5
02-23-2012 12:04 AM
Greate news I have dozens of SPA phones and I can't use them
