Command to turn on diagnostic information
mattfuerst
Greetings all,
We've got a UC 560 with the T1/PRI interface card.
Tomorrow we're switching our PRI service. We've got everything run up to the 560, tomorrow is just cable swap time for me and number port time for our provider.
My biggest concern is with the number of digits being handed off by the circuit. We asked the provider to pass the same number of digits (if I remember correctly, it's only the last 3 digits). I know there is a command on the 560 (via the console cable) where it will output the information (debugging output via the console cable) being passed by the T1 circuit. This was how we troubleshot this the last time (when we switched out T1 from our old Nortel to the 560, and we didn't know the number of digits being handed off by the circuit).
Can anyone suggest the proper command? I believe it falls under the realm of the show command, but I'm not certain.
paolo bevilacqua
debug isdn q931, with terminal monitor.
As with all commands, you don't need a console cable, just telnet to the device.
Absolutely perfect. Thank you Paolo!
Thank you for the nice rating and good luck!
