03-25-2010 01:07 PM - edited 03-21-2019 02:21 AM
I am trying to configure a trunk sip for SP9000.
The question is: how works the spa9000, like SIP Trunk or like SIP line (B2BUA)?
My ISP, give me only the ip sip server. They don not use other parameter like username or password. How can I configure the SPA9000 with this mode?
03-25-2010 08:04 PM
Your question is most interesting, you said your Internet telephone service provider (ITSP) doesn't use parameter like username or password.
I can only guess as to what mechanism your Internet telephone service provider (ITSP) uses to make sure that incoming SIP callers have an account on their network.
You may like to mention the name of this ITSP so that other people at this community could try to answer your question.
However, there are a lot of manuals and information for this product, at this site and as well as at www.cisco.com, but in English..
Following link for some material found here;
https://www.myciscocommunity.com/docs/DOC-1751
regards Dave
04-12-2010 08:13 AM
You have found the answer to this question. At me the same problem and I do not know as it to solve. I start to be disappointed in Linksys (CISCO)!!!
04-12-2010 08:18 AM
Dear Sirs;
Try the following:
On the line, please set the following:
- Proxy: IP address of the SP server
- User ID: 100
- Leave password blank
- Set the following parameters to YES: Make call without registration, Answer call without registration.
Submit changes, it should work.
Regards;
Alberto
04-12-2010 08:40 AM
Thanks for the answer!!!
While has earned nothing.
Has adjusted Syslog.
In line1 has put - SIP Debug Option: Full
At a call on Line1 in syslog there are no messages.
So should be?
Config on Line1
Line Enable: | |||
Network Settings | |||
SIP ToS/DiffServ Value: | SIP CoS Value: | [0-7] | |
RTP ToS/DiffServ Value: | RTP CoS Value: | [0-7] | |
SIP Settings | |||
SIP Transport: | SIP Port: | ||
SIP 100REL Enable: | Auth Resync-Reboot: | ||
SIP Proxy-Require: | SIP Remote-Party-ID: | ||
SIP GUID: | SIP Debug Option: | ||
Restrict Source IP: | Referor Bye Delay: | ||
Refer Target Bye Delay: | Referee Bye Delay: | ||
Refer-To Target Contact: | Auth INVITE: | ||
Use Anonymous With RPID: | Use Local Addr In FROM: | ||
Subscriber Information | |||
Display Name: | User ID: | ||
Password: | Use Auth ID: | ||
Auth ID: | Call Capacity: | ||
Contact List: | |||
Cfwd No Ans Delay: | |||
Dial Plan | |||
Dial Plan: | |||
NAT Settings | |||
NAT Mapping Enable: | NAT Keep Alive Enable: | ||
NAT Keep Alive Msg: | NAT Keep Alive Dest: | ||
EXT SIP Port: | |||
Proxy and Registration | |||
Proxy: | |||
Outbound Proxy: | |||
Use Outbound Proxy: | Use OB Proxy In Dialog: | ||
Register: | Make Call Without Reg: | ||
Register Expires: | Ans Call Without Reg: | ||
Use DNS SRV: | DNS SRV Auto Prefix: | ||
Proxy Fallback Intvl: | Proxy Redundancy Method: | ||
Mailbox Status: | Mailbox Subscribe URL: | ||
Mailbox Deposit URL: | Mailbox Subscribe Expires: | ||
Mailbox Manage URL: | VMSP Bridge: | ||
CFWD Bridge Mode: | XFER Bridge Mode: |
05-19-2010 02:13 PM
Try setting the following:
Register: No
I have a SPA9000 setup in our lab and it works (Thinktel Communications SIP trunk)
Martin
Martin Evers
Account Manager
T. 780.801.0550
F. 780.702.2880
04-12-2010 08:56 AM
Please, answer on my questions.
04-12-2010 10:17 AM
Thanks for the answer!!! While has earned nothing. Has adjusted Syslog.
In line1 has put - SIP Debug Option: Full At a call on Line1 in syslog there are no messages. So should be?
If I ITSP has given out me telephone number 2689259, it should not be registered in USER ID ??==========================================================================
It prompt than is possible to check up SIP trunk from ITSP, works or not?
04-12-2010 10:29 AM
Dear Sir;
Yes, you can/must use the telephone number on the user id.
On the syslog, you need to go to the system tab and include the syslog server IP address in order to get the traces.
Alberto
04-12-2010 08:47 AM
- User ID: 100
