09-19-2011 07:38 AM - edited 03-21-2019 04:41 AM
Hi, can anyone point me to the some literature about configuring spa9000 and 942 phones?
I basically have 2 questions I have to sort:
My setup is: spa9000 + 2 phones spa942.
1. I am having issues with configuring busy lamp on both phones, so if 1 phone is in use the other phone shows busy lamp and vice versa.
2. If I want to add another 2 phones (942), do I need any special licenses, or just the matter of plugging the phones into switch?
Can I use different phones, which ones would you recommend?
I would be very grateful for any response as I am still a novice in that field. Thanks
09-30-2011 09:50 AM
Not sure what you mean by busy lamp, but you can control whether a caller knows the phone is busy by toggling the dnd softkey.
Regarding item 2, you can up to 16 phones to the spa9000.
10-07-2011 06:12 AM
Thanks for reply,
I have another issue whenever running wizard it finds that soft on pbx and phones is old and trying to update it.
It has upgraded the pbx but i cannot upgrade the phones, it says 'upload was incomplete ' . Do you know what would be the issue?
If I have already 2 phones and want another 2 do I need any licenses for them?
10-07-2011 09:17 AM
It's hard to determine what's wrong with the upgrade, you can run debug log to see what is happening.
Link to do this is at
https://supportforums.cisco.com/docs/DOC-9862
Regarding the license issue, no need for this. The spa9000 will accept up to 16 spa phones with the latest software release which is 6.1.5.
10-10-2011 06:14 AM
10-10-2011 09:52 AM
It's saying the download file is corrupted.
Try to download the phone software again from cisco.com.
10-11-2011 05:04 AM
I tried all of them versions.
