Configure Caller ID for incoming calls on UC320 FXO's
digitalchild
I've been digging around trying to work out how to set up caller id from incoming calls on any of the FXO's on the UC320 but can't seem to find the information in either the manual or in the web administration.
Is this possible?
thanks.
jeffsand
Hi Jamie,
It is not currently possible to configure the Caller ID that is displayed for incoming FXO calls but if your FXO Service Provider delivers Caller ID that is what should get displayed on your incoming calls.  If not, you might need to open a case with the Small Business Support Center.
Jeff
