Showing results forĀ
Search instead forĀ
Did you mean:Ā
configuring features button for cisco 8961/9951 phones on UC540
jeremy meng
I'm looking for some help to configure pick up and group pick up with programmable features buttons (not available with soft key button if i understand) by CLI: i can't use Cisco Unified Communications Manager administration.
I set the dn and add it the  pick-up group . Then i create a template and assign it to the register pool of my phone .
Below, the configuration i try to set for a 8961 sip phone.
voice register dn  3
number 2044
call-forward b2bua all 5000
call-forward b2bua busy 2099
call-forward b2bua noan 2040 timeout 20
call-forward b2bua unregistered 2099
pickup-group 1
name thomas
no-reg
label thomas
voice register template  1
feature-button 1 NewCall
feature-button 2 Cfwdall
feature-button 3 Redial
feature-button 4 GpickUp
softkeys idle  Gpickup Pickup
UC_540(config)#do sh voice register pool 3
Pool Tag 3
Config:
  Mac address is D824.BDBA.0EE2
  Type is 8961
  Number list 1 : DN 3
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Cisco-CP8961/9.2.1
  DTMF Relay is enabled, rtp-nte
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  speed-dial 1 2045 label 2045
  speed-dial 2 2042 label 2042
  speed-dial 3 2041 label 2041
  keep-conference is enabled
  registration expires timer max is 600 and min is 60
  username XXXX password XXXX
  template is 1
  kpml signal is enabled
  Lpcor Type is none
  Transport type is tcp
  service-control mechanism is supported
  registration Call ID is d824bdba-0ee20002-2a60e3bc-29be0a44@10.10.78.17
  Registration method: bulk - completed
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 2044
  contact IP address: 10.10.78.17 port 49718
  Phone SIS Version:  5.1.0
  GW SIS Version:  1.0.0
Dialpeers created:
Dial-peers for Pool 3:
dial-peer voice 40003 voip
destination-pattern 2044
session target ipv4:10.10.78.17:49718
session protocol sipv2
dtmf-relay rtp-nte
digit collect kpml
codec  g711ulaw bytes 160
  call-fwd-busy        2099
  call-fwd-noan-timeou 20
  call-fwd-noan        2040
  call-fwd-all         5000
  after-hours-exempt   FALSE
When i reload the phone i can't see the new features
Looking for some help to see what i forget ?
Thanks you.
0 Replies 0
