10-10-2012 11:11 AM - edited 03-21-2019 06:24 AM
Hello. I have a network set up with a UC560 on one end and a UC540 on the other end. These two sites are connected via a point to point connection.
Both UC500's have been configured entirely using CCA.
I have Multisite manager configured to connect the 2 sites, but when configuring it it appears to need the WAN address of the remote UC. The WAN port on the remote UC is connected to a Cable ISP, and does not go through the point to point connection. Multisite manager does not allow me to use the VLAN1 IP to connect the 2 UCs.
Long question short: Is there a way to set up Multisite manager to connect the Uc devices via the VLAN1 IP/internal network?
10-10-2012 02:11 PM
Hello Jared,
To use CCA you should use the WAN address from both sides. They also should be reachable from each end.
HTH,
Alex
10-11-2012 06:43 AM
Thank you for your reply. So with the way the network is currently configured, I cannot do that in CCA. What changes would I have to make in the CLI in order to facilitate this?
10-15-2012 07:28 AM
So, is this the only way, or is there a way to accomplish this via the CLI?
