Hi there,
I need to configure UC560 System with 10 to 12 teleworker sites with 5 users in each of the teleworker site and 20 users at the Main site (HQ).
Can I use SPA8800 gateway in teleworker site to connect to HQ UC560?
SPA8800 is used to connect analog phones, that do have the features needed in a modern system, for that your should use IP phones.
Thank you for the prompt reply Paolo. I might not have been clear with my question. Here is what I need:
To establish VPN, you will need a router at each site router, not SPA8800.
You will also need to engage a reputable consultant, or UC certfied cisco partner for design and configuration. The product are not meant to be configured by the end user.
