10-29-2010 07:03 AM - edited 03-21-2019 03:12 AM
Sorry for crossposting this under the XML-application discussions as well, turned out there is not much activity there so I might be better of here...
In the Cisco App Developer notes it says cookies are supported but I'm unable to get my SPA504G (7.4.6) to return the cookie I set, hence it ends up creating a new session for every request. Are cookies supported on the SPA500-series when using XML services or is that yet to come? Page 5-5 in that document mentions that cookies should work.
Thanks in advance!
Solved! Go to Solution.
11-02-2010 04:04 PM
This issue will be fixed in the next release. Thank you.
11-02-2010 04:04 PM
