CUCM 8.0 maximum voice calls
Kruemel2oo2
i have a question regarding the CUCM 8.0.
What is the limitation of maximum voice call's at the same time.
I need to work this out, to get a full license.
Thanks in advance.
Jörg
jurodri3
Hello Mr. Friese,
According to the information found the maximum voice calls depends of the device.
Let me share with you the chart found:
Conference Bridge Type
Description
Cisco Conference Bridge Hardware
(WS-6608-T1                or WS-6608-E1)
This type supports the Cisco Catalyst 4000 and 6000 Voice Gateway                Modules and the following number of conference sessions.
Cisco Catalyst 6000
G.711                or G.729a conference—32 participants per port; six participants                maximum per conference; 256 total participants per module; 10                bridges with three participants
GSM—24                participants per port; six participants maximum per conference;                192 total participants per module
Cisco Catalyst 4000
G.711                conference only—24 conference participants; maximum of four                conferences with six participants each
Cisco Conference Bridge                Software
Software conference devices support G.711 codecs by default.
The maximum number of audio streams for this type equals 128. With                128 streams, a software conference media resource can handle 128                users in a single conference, or the software conference media                resource can handle up to 42 conferencing resources with three                users per conference.
Caution If                the Cisco IP Voice Media Streaming Application service runs on the                same server as the Cisco CallManager service, a software                conference should not exceed the maximum limit of 48 participants.
Cisco IOS Conferencing and                Transcoding for Voice Gateway Routers
Uses                the NM-HDV or NM-HDV-FARM network modules.
G.711                a/mu-law, G.729, G.729a, G.729b, and G.729ab participants joined                in a single conference
Up                to six parties joined in a single conference call
Cisco Unified Communications Manager assigns conference resources                to calls on a dynamic basis. In a Cisco Unified Communications                Manager network that includes both Cisco IOS Conferencing and                Cisco IOS Enhanced Conferencing, set the Cisco CallManager service                parameters, Maximum Ad hoc Conference and the Maximum MeetMe                Conference Unicast, to six conference participants.
For more information about                Cisco IOS Conferencing and Transcoding for Voice Gateway Routers,                see the IOS documentation that you received with this product.
Cisco IOS Enhanced                Conferencing and Transcoding for Voice Gateway Routers
Uses                the onboard Cisco Packet Voice/Fax Digital Signal Processor                Modules (PVDM2) on the Cisco 2800 and 3800 series voice gateway                routers or uses the NM-HD or NM-HDV2 network modules.
G.711                a-law/mu-law, G.729, G.729a, G.729b, G.729ab, GSM FR, and GSM EFR                participants joined in a single conference
Up                to eight parties joined in a single call.
Tip In                Cisco Unified Communications Manager Administration, ensure that                you enter the same conference bridge name that exists in the                gateway Command Line Interface.
For more information about                Cisco IOS Enhanced Conferencing and Transcoding for Voice Gateway                Routers, see the IOS documentation that you received with this                product.
Cisco Video Conference                Bridge (IPVC-35xx)
This conference bridge type                specifies a dual multimedia bridge that provides video                conferencing. The Cisco Video Conference Bridge provides audio and                video conferencing functions for Cisco IP video phones, H.323                endpoints, and audio-only Cisco Unified IP Phones.
Cisco Conference Bridge                (WS-SVC-CMM)
This conference bridge type supports the Cisco Catalyst 6500                series and Cisco 7600 series Communication Media Module (CMM).
This conference bridge type                supports up to eight parties per conference and up to 64                conferences per port adapter. This conference bridge type supports                the following codecs: G.711 mu-law, G.711 a-law, G.729 annex A and                annex B, and G.723.1. This conference bridge type supports ad hoc                conferencing.
Thank you
Diego Rodriguez
Cisco network engineer
If this answer was satisfactory for you, please mark the question as Answered.
Hello Mr. Friese,
Description
Cisco Catalyst 6000
Cisco Catalyst 4000
Hello Mr. Friese,
Description
Cisco Catalyst 6000
Cisco Catalyst 4000
Thank you
Diego Rodriguez
Hello Mr. Friese,
Description
Cisco Catalyst 6000
Cisco Catalyst 4000
Thank you
Diego Rodriguez
Hello Mr. Friese,
Description
Cisco Catalyst 6000
Cisco Catalyst 4000
Thank you
Diego Rodriguez
