ā03-17-2011 05:53 AM - edited ā03-21-2019 03:48 AM
Hi all,
I need to configure CUE AA on UC560 so that after the "after business hours" prompt the call in being transferred to a night shift person but automatically without choosing any option. I have the AA script editor and tried few things but donĀ“t work really, how can I do that o is there any ready script with such funcionality? The script has to include the full menu with all the options from 0 to 9, * and #.
Thanks in advance.
ā03-17-2011 06:12 AM
This is part of the AA_SBCS_V03 script and CCA 3.0.1 AA menu.
Its called no action Transfer and is below the menu options in the GUI.
ā03-17-2011 06:20 AM
Thanks for response Steven. Is this script available for CUE configuration via web? If so, where get I get it?
Thanks.
ā03-17-2011 06:26 AM
Its in the SW Pack for UC5xx. And should be on your flash: :-)
SWP: In a zip file within the main zip called support files.
FLASH:
UC560#cd auto
UC560#cd autoattendant
UC560#dir
Directory of flash:/autoattendant/
109 -rw- 94503 Jan 27 2011 15:02:00 -05:00 AA_SBCS_v01.aef
110 -rw- 96166 Jan 27 2011 15:02:00 -05:00 AA_SBCS_v02.aef
111 -rw- 130488 Jan 27 2011 15:02:02 -05:00 AA_SBCS_v03.aef
112 -rw- 15891 Jan 27 2011 15:02:02 -05:00 AA_transfer.aef
254029824 bytes total (66924544 bytes free)
UC560#
You should be able to configure it with CUE Editor (http://10.1.10.1) too I suppose.
ā03-17-2011 06:38 AM
Thank you very much Steven. I found it. Now I need to expore it and modify if needed.
