CUE Bakcup failed from CLI and CCA
diego_ers
Hello Guys...
I have been trying to backup a UC560 from the CCA but in it failed when is trying to backup the CUE.
Here it is the log of the backup
Thanks for any help
#Start Operation
Category:      Data
Backup Server: ftp://172.20.7.44/ftp/
Operation:     Backup
Backupid:      6
Date:          Tue Nov 06 16:36:22 EST 2012
Result:        Failure
Reason:        Script execution failed: Voicemail Backup failed
Version:       8.0.6
#End Operation
#Start Operation
Category:      TimeCardView
Operation:     Backup
Backupid:      6
Result:        Success
Reason:
Version:       8.0.6
#End Operation
#Start Operation
Category:      Configuration
Operation:     Backup
Backupid:      6
Date:          Tue Nov 06 16:36:24 EST 2012
Result:        Success
Reason:
Version:       8.0.6
#End Operation
#Start Operation
Category:      HistoricalData
Operation:     Backup
Backupid:      6
Date:          Tue Nov 06 16:36:26 EST 2012
Result:        Success
Reason:
Version:       8.0.6
#End Operation
5 Replies 5
paolo bevilacqua
Update CUE software and try again.
Hello Diego,
Just to add to what Paolo has already said update to CUE version 8.6.5.
HTH,
Alex
Problem with updating CUE with this bug is that the update uses the same scripts to backup and restore settings so updating it might fix the problem but you won't have a good backup to restore too.  I have been through this with 4 of my UC5xx.
Guys I just upgrade the CUE software to version 8.6.3 and i still have the same issue:
#Start Operation
Category:      Data
Backup Server: ftp://172.20.7.45/cue/
Operation:     Backup
Backupid:      1
Description:   backup02
Date:          Fri Nov 16 11:46:42 EST 2012
Result:        Failure
Version:       8.6.3
#End Operation
What else i can try?
Hello Diego,
Version 8.6.5 as said in previous message.
Best regards,
Alex
