DDNS - CCA
jcarter
Level 4
Level 4
Is there a way to setup DDNS for a UC500 using the CCA?
DDNS is not configurable today via CCA, but it is a committed feature for our next release, 2.1. Stay tuned.
Marcos
Based on the following config items, where do I put my dyndns.org username and password?
! Define the DDNS global settings
ip domain lookup source-interface FastEthernet0/0
ip domain name dyndns.org
ip ddns update method method1
http
add
! As there is a “?” in the CLI – there will be an error if you copy / paste this line as is. You need to
! first paste the CLI before the “?”, then hit “Ctrl +V”, type ? and then paste the rest of the CLI
http://uc520multi:cisco123@members.dyndns.org/nic/update?system=dyndns&hostname=cisco123@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
interval maximum 2 0 0 0
interval minimum 1 0 0 0
Configure WAN interface for DDNS and VPN
description $FW_OUTSIDE$
ip dhcp client update dns
ip ddns update hostname SANJOSE-UC520.dyndns.org
ip ddns update method1
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_HIGH out
ip virtual-reassembly
duplex auto
speed auto
Hi Jason,
The following document has some configuration examples and the full description of the DDNS feature in IOS:
http://www.cisco.com/en/US/partner/docs/ios/ipaddr/configuration/guide/iad_ddns_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Marcos
