dial peer configuration for trunk selection
rinchu.raj
  I had extablished VPN connection between two UC56 and VOIP dialing is going on with in two offices. I need to extend the configuration for selection trunk lines from second site from first site to call outside office. What Dial Peer configuration I need to do for getting it active.
Rinchu
6 Replies 6
paolo bevilacqua
Are you using a  CCA or CLI configuration ?>
Via CCA I had done the configuration for both system....
rinchu.raj
kindly help me to overcome this issue..........
Sent from Cisco Technical Support Android App
i am not sure what exactly you want to do, you can use "preferece" under dial-peer to choose trunk
dial-peer voice xxx pots(voip)
preference <0-10>
0 is the highest priority.
I done the configration via CCA  and the running conf i can see two voip dial peer. this is the site where all trunk line roured. Customer from other site2 needs to call outside by taking line from site1.
dial-peer voice 2100 voip
corlist incoming call-internal
description **CCA*INTERSITE inbound call to SITE 1
translation-profile incoming multisiteInbound
incoming called-number 82...
voice-class h323 1
dtmf-relay h245-alphanumeric
fax protocol cisco
no vad
dial-peer voice 2101 voip
description **CCA*INTERSITE outbound calls to SITE2
translation-profile outgoing multisiteOutbound
destination-pattern 81...
session target ipv4:192.168.50.1
voice-class h323 1
fax protocol cisco
no vad
no dial-peer outbound status-check pots
site1 has a trunk but site2 has not, so site2 need to use trunk in site1, is this what you want to deploy, the answer will be no, UC500 in each site should have its own trunk since they do not sync the call control information each other
