02-09-2010 09:45 AM - edited 03-21-2019 02:08 AM
How can I disable CDP on my WAN port. Preferably CCA.
02-09-2010 09:49 AM
There is no way to do this in CCA. You will need CLI:
UC500#conf t
Enter configuration commands, one per line. End with CNTL/Z.
UC500(config)#int fast 0/0
UC500(config-if)#no cdp enable
UC500(config-if)#end
Marcos
02-09-2010 10:04 AM
Remember that CDP should only be disabled on your UC500 WAN port if the WAN port is not connected to a SR520, SA520, or SA540. If your WAN port is connected to a SR520, SA520, or SA540, CDP needs to be enabled on the UC500 WAN port for CCA to work properly.
