Disabling Live-Record tones on UC540
Mike Wyzykowski
Is there any way in the CUE CLI to disable the tones when using Live Record?  I am currently running Unity Express 7.03. In CUE CLI I found these command choices but I am unsure of how to apply them:
voicemail live-record beep duration and voicemail live-record beep interval
The goal is to not have any tone played.  Any help would be greatly appreciated.
Thank you,
Mike
8 Replies 8
Steven DiStefano
Can't be done. Cue GUI can be used to disable periodic beeps, but
initial beeps can't be eliminated.
In 38 states in the US, the party being recorded must be informed, but
I agree it would be nice to have it as an option. This input has been
given to the CME team several times, but there is no change planned.
Steve DiStefano
Technology Solutions Architect - Sales
Cisco Systems
Research Triangle Park
North Carolina, U.S.A
1.919.392.6219
www.cisco.com/smb
On Jul 21, 2010, at 3:34 PM, "mikewyzo"
So to disable the tones during the call, not the initial tones what would that be?
Would like to disable the periodic tones used by LiveRecord...
This feature is planned for CCA 3.0 (targeted December 2010).
- Anna
So any idea what code to right now to have this work?
Thanks!
Chris Avants – CSE, MCSE, CCNA, CCDA, CCNP, CCVP
Business Development
L3 Technologies
(956) 467-1410 Office
(956) 429-1866 Cell
(956) 688-8332 Fax
Chris@L3TX.com
www.L3TX.com
Unified Communications Experts!
Voice-Video-Data-Wireless-Security
For on-line ordering and product information Visit http://www.L3Store.com
Sent from my iPhone
It may be worth a shot looking in the CUE GUI (web browser to 10.1.10.1),
And look for an option to uncheck periodic beeps. I have seen it there.
Is there an update on this, was it released in version 3?
Bob James
Hi Bob,
I have just recently used CCA to configure a UC-560 and UC-540 and in both situations I was able to turn of the periodic tones during the setup process. However what I have not tried yet is changing this setting after it has been setup so I cannot verify if this can be done just yet.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Steven DiStefano
Yes, it's in CCA 3.0. It's under Conference configuration GUI.
