divert incoming call direct to mobile
jonathang
Beginner
Beginner
Can anyone advise.
I need to have one of our did's divert directly to a mobile number.
What's the best way to do this.?
It it possible just to map the DID number direct to a mobile?
Alexander Maroukian
Rising star
Rising star
Hello Jonathan,
The easiest way is if this DID is set on a phone - forward it from the phone by pressing CallForwardAll button and enter the number to which the call should be forwarded.
HTH,
Alex
*Please rate helpful posts
Yes I agree but I want to do it without a handset/phone. So there is no possibility of it getting switched off accidentally.
