Hi Guys,
I am wondering, since DMVPN and rip is capable on the ios that is on the UC 500, why wouldn't we want to use that instead of the crypto map vpn? In a full mesh this would be so much less coding. You can still do easyvpn or sslvpn on top of that. This would make the multisite configuration way easier, and you could have it integrate into several different routers.
Is this something that might come into CCA?
On the topic of multisite vpn... currently it looks like the multisite manager doesn't give you the option of using existing gateways (for instance if you had two metro ethernet connections you would still have to use vpn of the uc's). Is this going to be changed in the future?
Thanks!
