08-01-2012 11:06 AM - edited 03-21-2019 06:06 AM
HI, I am investigating how to use the UC540 with Polycom phones such ax VX500. Does anyone have information on whether it is possible?
Joe Brown
Noviant
08-01-2012 12:20 PM
Hello Joe,
I can tell you that we don't support any 3rd party SIP phones on the UC500 series platform. As for whether it is possible to use the Polycom phones with the UC540 I couldn't tell you. I have seen other forum post where users have been able to successfully register 3rd party SIP phones: https://supportforums.cisco.com/message/3680375
-john
08-01-2012 12:24 PM
Thanks.
Joe Brown
08-02-2012 04:53 PM
Hi Joe,
The answer is yes, however it cannot be done via CCA and is purely a command line configuration.
Then there is the obvious question though WHY?
If it is to save costs so you don't have to buy new Cisco Phones, then this will probably cost you more to implement as doing any sort of out-of-band configuration will result in no SBSC support on the system, and a major headache to continue to maintain.
But yes it can be done, and has been done quite a few times, but there is a warning with the Polycom phones... All new firmware updates have the phones preferred operation in G.722 Codec, this may not be fully supported on the UC-500 as of yet, it is what has blind sided a couple of people I know of already
Cheers,
David Trad.
