05-26-2019 11:15 AM
he gens
on cme installed on 2811 (Cisco IOS Software (C2800NM-SPSERVICESK9-M), Version 12.4(24)T2)
analog phones on EM-HDA-8FXS stopped working no dial tone?
router#sh inv
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V03 , SN: FHK1032F1CJ
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V01 , SN: FOC1035336M
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC10292VC7
NAME: "AIM Service Engine 0", DESCR: "AIM Service Engine"
PID: AIM-CUE , VID: V03, SN: FOC140941RC
NAME: "High Density Analog Voice Module on Slot 1", DESCR: "High Density Analog Voice Module"
PID: NM-HDA-4FXS , VID: V01 , SN: FOC10112L9R
NAME: "Eight port FXS voice interface daughtercard on Slot 1 SubSlot 1", DESCR: "Eight port FXS voice interface daughtercard"
PID: EM-HDA-8FXS , VID: V01 , SN: FOC10322BGM
router#sh dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
router#
#sh voice port
Foreign Exchange Office 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 60 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 350 ms
OPX Ring Wait Timing is set to 6000 ms
Foreign Exchange Office 0/0/1 Slot is 0, Sub-unit is 0, Port is 1
Foreign Exchange Office 0/0/2 Slot is 0, Sub-unit is 0, Port is 2
Foreign Exchange Office 0/0/3 Slot is 0, Sub-unit is 0, Port is 3
Foreign Exchange Station 1/0/0 Slot is 1, Sub-unit is 0, Port is 0
Type of VoicePort is FXS
Echo Cancel Coverage is set to 64 ms
Supervisory Disconnect Time Out is set to 750 ms
Station name None, Station number 2000
Caller ID Info Follows:
Standard BELLCORE
Output attenuation is set to 14 dB
Caller ID is transmitted after 1 ring(s)
Ring Frequency is 25 Hz
Ring Active Status is inactive
Tip Ground Status is active
Hookflash-in Timing is set to max=1000 ms, min=150 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
Foreign Exchange Station 1/0/1 Slot is 1, Sub-unit is 0, Port is 1
Foreign Exchange Station 1/0/2 Slot is 1, Sub-unit is 0, Port is 2
Foreign Exchange Station 1/0/3 Slot is 1, Sub-unit is 0, Port is 3
