02-24-2014 01:48 AM - edited 03-21-2019 08:06 AM
Hi All.
I've come up with some error and can't find an answer what is causing that.
There is UC560 and 3rd party Door phone configured over SIP protocol. When i assign ip address of voice vlan to that phone it's not reachable, but when it's on data vlan then it's reachable but i'm getting this kind of error:
SIP/2.0 400 Request-URI MUST NOT have user
There is some config and debugging:
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol pass-through g711alaw
no fax-relay sg3-to-g3
sip
registrar server expires max 3600 min 3600
outbound-proxy ipv4:88.11.22.33:5060
no update-callerid
sip-profiles 1000
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 5
max-pool 5
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
time-format 24
create profile sync 0002444005002498
voice register dn 1
number 441
name doorbox
no-reg
voice register pool 1
id mac 0002.D619.0001
number 1 dn 1
dtmf-relay rtp-nte
username 441 password 12345
codec g711ulaw
no vad
And debugging:
Received:
REGISTER sip:441@10.1.1.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.175:5060;rport;branch=z9hG4bKPjzBkGsf92m-hRYybMttoDDAFgZ72Rv.SU
Max-Forwards: 70
From: <sip:441@10.1.1.1>;tag=9PhVyBvfTMgz0nYukYXX7ubo.VZplwtt
To: <sip:441@10.1.1.1>
Call-ID: gOBtNc3mNu2nnsQoiawp4vmqjk.rknhS
CSeq: 24450 REGISTER
Contact: <sip:441@192.168.1.175>
Expires: 1800
Allow: INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, OPTIONS, INFO
Content-Length: 0
028232: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.1.175,Port 5060, Transport 1, SentBy Port 5060
028233: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 192.168.1.175,Port 5060, Transport 1, SentBy Port 5060
028234: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 192.168.1.175,Port 5060, Transport 1, SentBy Port 5060
028235: //-1/9FE1CF99B825/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
028236: //-1/9FE1CF99B825/SIP/Transport/sipSPITransportSendMessage: msg=0x8C9F77C4, addr=192.168.1.175, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x0
028237: //-1/9FE1CF99B825/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
028238: //-1/9FE1CF99B825/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
028239: //-1/9FE1CF99B825/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x8C9F77C4 to default port=5060
028240: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.1.175, rport:5060 with laddr:
028241: //-1/9FE1CF99B825/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x8C9F77C4
028242: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8C9F77C4, addr=192.168.1.175, port=5060, local_addr=, connId=3 for UDP
028243: //-1/9FE1CF99B825/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
028244: //-1/9FE1CF99B825/SIP/Transport/sipSPITransportSendMessage: msg=0x8C9D225C, addr=192.168.1.175, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x814ACF94
028245: //-1/9FE1CF99B825/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
028246: //-1/9FE1CF99B825/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
028247: //-1/9FE1CF99B825/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x8C9D225C to default port=5060
028248: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.1.175, rport:5060 with laddr:
028249: //-1/9FE1CF99B825/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x8C9D225C
028250: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8C9D225C, addr=192.168.1.175, port=5060, local_addr=, connId=3 for UDP
028251: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 20 Feb 2014 16:05:17 GMT
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
028252: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
IPT-UC560#SIP/2.0 400 Request-URI MUST NOT have user
To: <sip:441@10.1.1.1>;tag=2500D288-1EB9
Content-Length: 0
If anybody would have a clue of is that I'll be highly appretiated.
03-07-2014 02:04 AM
It looks like tough question guys.
I've just got one question: Is it a misconfig on UC560 and it can be fixed by adding some commands or that SIP door phone is not supported or not compatible with CME?
Any debug commands i can use to confirm that?
Cheers,
03-07-2014 03:59 AM
You may try to add the following under voice register global:
authenticate register
authenticate realm all
tftp-path flash:
Also you should set the the device in the voice vlan.
HTH,
Alex
*Please rate helpful posts
03-07-2014 07:54 AM
Hi Alex.
Thanks for your reply.
I'll try to implement those commands when i get to a client site next time.
I tried to put that phone on voice vlan and connected to a switch port which is used for normal ip phone but it was no connectivity after that i couldn't ping CME. Once i assigned data vlan ip address the connectivity was restored, and the door phone was trying to connect. I think it should work on both vlans.
Cheers,
01-16-2015 05:27 PM
got the same problem with a 2n ip vario an uc540
try to change the port role to switch vlan100 (or whatever you set for voice-vlan)
