Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
1775
Highlighted
Beginner
Error setting up NAT from CCA2.1
inluded is the screen shot...
UC520
Anyone else having this?
Going into security - NAT
Just adding a basic NAT
click apply and error
Everyone's tags (5)
6 REPLIES 6
Beginner
Re: Error setting up NAT from CCA2.1
this error happens with a default config, I tested in our lab.  Anyone doing NAT from CCA2.1?
updated pic also, maybe more clear... also attached.  I can delete the Firewall settings, delete the NAT settings.  Create a vlan, try to use NAT and BOOM, error
Enthusiast
This may be a configuration error. Are you trying to use vlan 100 for outside interface? VLAN 100 is used for voice subnet. You may want to use interface fastethernet 0/0 (WAN) for outside interface.
-Saurabh
Beginner
of course im using FastEthernet0/0.
From a brand new config this is how the error is reproduced.
First delete all firewall settings
Second delete NAT settings
create a VLAN, say 50, create DHCP pool, etc
Make sure FastEthernet0/0 is DHCP
now go into NAT, and try anything that makes a change and requires saving...  BOOM  error
this is with CCA2.1
from the CLI I have NAT outside for FastEthernet0/0
Nat inside for the VLANs 1 and 50, but not the BVIs (maybe thats an issue)
I also have attempted doing the "VLAN database" and recreating the vlan.dat
so I can ping from the FastEthernet0/0 to outside, but can not ping the outside from any other interface (vlan)
Enthusiast
Let me run this scenario by the CCA engineering team.
-Saurabh
Beginner
problem is resolved in CCA 2.1.1   !!!!!!!
thanks for the good news!!!!!
