Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1285
gustavolsson
Beginner
exotic characters in SPA525G/G2
I'm having some issues with displaying "exotic" characters in the phone display of the SPA525G2. For the SPA50x- and SPA9xx-series I set the charset http-header to "ISO-8859-1". Characters above unicode 0x7F are escaped to their unicode equivalent (this is OK according to documentation). This works well on the aforementioned series but not on the SPA525G/G2 (7.4.6). I have tested different settings; setting the charset-header to "UTF-8", not escape the chars above 0x7F and so on, but I can't seem to get it to work. It's not a display-issue since when I enter the characters in the web GUI they are showed OK in the phone display.
Any hints or pointers? Thanks!
3 REPLIES 3
Alberto Montilla
Dear Gustav;
Sorry for the delay answering. I have escalated your issue. Stay tuned.
Alberto
Hi Alberto, any news on this? We've run into a related issue where the phone totally locks up if the first character in a field is an "exotic" character, compared to when it just does a bad interpretation if the character is present later in the setting value, example:
Åsa Svensson
...locks up the phone, whereas
Svensson Åsa
just shows a "defect" version of that setting. I'm thinking this might be due to the charencoding affecting the "xml"-syntax and the clause isn't closed properly?
I would really appreciate a solution to this since names with these characters are very common in Sweden.
Hi Gustav,
I've sent you a private message so you can contact me via email. This will allow me to replicate the issue and get it fixed as soon as possible.
Patrick
