Expanding wireless coverage in UC300W
hcaceresm
I can use the Linksys RE1000 Wireless-N Range Extender/Brige with UC320W for increase the coverage ??
regards
group9optus
Cannot answer this straight but we have used WAP321 the new AP and it works nicely...
Hi Hamsel,
You might take a look at this thread for network requirements:
https://supportforums.cisco.com/thread/2146789?tstart=0
Chris
isiconsultants
Yep, it works fine, UC320W and Linksys RE1000 Range Extendor works fine!; I have a customer with UC320; their box is in the basement area, there is concrete and wood floors that degrade the wireless signal so I tried an off brand, which was supposed to be commercial grade, didn't work!
As soon as I used the Cisco Linksys RE1000, it was off and running in less than 10minutes, too bad Cisco let go of Linksys.
The main component that required wireless access was a SmartTV by Vizio; it showed weak/poor signal but after I setup the RE1000 it paired with the UC320W without a problem and the SmartTV now shows strong signal all bars lite up.
I have Cisco support on the UC320W and they said as long as you use a WAP, Range Extender that works in the 2.4 frequency yo ushould be good.
-Hector
