Extension Mobility Intercom Feature
jaydien1358
Level 3
Level 3
I am setting up a 7960 phone for extension mobility. I would like to add a dialable intercom button to the phone profile for when no one is logged in and to the user profiles for each repective user.
However, if I change the amount of button to 2 and try to set button 2 to diable intercom, I am unable to do that. The only option for any of the buttona is normal or shared. Is this doable?
Please advise.
-Brian
Hello Brian,
Currently CCA only allows Normal and Shared lines to be set under the user and the phone profile.
HTH,
Alex
