06-19-2012 09:37 PM - edited 03-21-2019 05:56 AM
How do you change extension length from 4 digit to 3 digit?
Solved! Go to Solution.
06-20-2012 01:27 AM
3 Digit Extension is supported from 8.6.3 release of BE3K. Unfortunately, once you upgrade to 8.6.3, there is no easy way to change the extension length from 4 digits to 3 digits. You need to reinstall the system with 8.6.3 build and then select the extension length to 3 digits in First Time Setup.
Sanjay
06-20-2012 01:27 AM
Sanjay
06-20-2012 01:39 AM
Thanks for the reply Sanjay, i suspected that would be the answer. I will re-install and then select 3 digits in First Time Setup.
Paul
