09-27-2011 11:50 AM - edited 03-21-2019 04:43 AM
Is there any way I can configure some type of extension on the UC where I can dial and it can automatically drop my call?
I'm asking because we have a door phone that does not want to hang up for some reason. It will hunt few different numbers and no matter what I try, it will hang on to the call until someone presses the call button again to hang it up. My plan is to have this extension as the last hunt number so after trying different extensions, it'll call this extension and just hang up.
Thanks!
J
09-27-2011 12:08 PM
You can create a Unity/Unity Connection Call Handler that has no greeting and a post-greeting action of Hang Up.
09-27-2011 12:13 PM
looks like while searching for some answers, I ended up in the wrong section and posted my question here. My device is a UC520 and it runs CME with CUE. Thanks.
09-27-2011 07:07 PM
Hi J,
I guess what you could try is creating a floating extensions (If using CCA) or a dummy DN if using CLI, and set a call timer of 3 on it and no forwarders to any destination, the user then would hear a busy tone once the cycle is completed.
Cheers,
David.
09-28-2011 06:44 AM
hi David. Will this drop the call or will it be busy until it's manually dropped from either end? I am hoping I can set something up to auto drop the call.
J
09-28-2011 06:50 PM
Hi J,
It will free up the line at your end, but on the customer end they will continue to hear a busy tone... Well this is what should happen, but sometimes carriers have some funky configurations on their systems which may prevent this, things like exchanged based timers, but in general it should work.
Cheers,
David.
09-29-2011 05:08 AM
You can make an auto attendant without a no-option transfer and have the calls transferred to that extension. The auto attendant will drop the call after repeating itself. In your case you might need to record a really short and silent audio clip, like half a second to make it appear seamless.
09-29-2011 06:17 AM
Marcus,
That's exactly what I implemented lastnight and it worked great. I created an AA and used the built-in after hours prompt and it hangs up nicely after saying "We are currently closed. Please call back later".
Thanks Marcus and David for help.
J
