Failed to authenticate with the device at ip.ip.ip.ip using TELNET
Arturo Bianchi
Hi!
I can no longer use CCA :-)
I tried everything, but when I enter user and password after waiting a few tens of seconds I get the following error window: "Failed to authenticate with the device at ip.ip.ip.ip using TELNET. TELNET access is required for access to voice configuration. Cannot continue. Exiting CCA."
Given that I do not understand the need to use the 'telnet', I verified that UC500 was reachable from the PC via telnet. But CCA 2.2.5 don't work and I find no reason, even logging on to see go console error messages or anything else that turn me to the solution. Before removing CCA and back to 2.2.4, I see if I could solve the problem somehow.
I tried to see what was going on the network with wireshark:
Time          Source          Destination     Protocol     Info
722.508214     pc.pc.pc.128     uc.uc.uc.1     TELNET     Telnet Data ... (the password in clear text!!!!)
722.713551     uc.uc.uc.1     pc.pc.pc.128     TCP     telnet > xs-openstorage [ACK] Seq=80 Ack=37 Win=4092 Len=0
722.713606     pc.pc.pc.128     uc.uc.uc.1     TELNET     Telnet Data ... (a '/r/n' after send user pwd on previus pkt)
722.911528     uc.uc.uc.1     pc.pc.pc.128     TCP     telnet > xs-openstorage [ACK] Seq=80 Ack=39 Win=4090 Len=0
724.608892     pc.pc.pc.128     uc.uc.uc.1     TCP     xs-openstorage > telnet [FIN, ACK] Seq=39 Ack=80 Win=65456 Len=0
724.611192     uc.uc.uc.1     pc.pc.pc.128     TCP     telnet > xs-openstorage [ACK] Seq=80 Ack=40 Win=4090 Len=0
724.721538     uc.uc.uc.1     pc.pc.pc.128     TELNET     Telnet Data ... (a '/r/n')
724.721589     pc.pc.pc.128     uc.uc.uc.1     TCP     xs-openstorage > telnet [RST, ACK] Seq=40 Ack=82 Win=0 Len=0
...but do not understand why the PC ends the connection!
NB: Obviously the username and password are correct and the UC does not report login errors.
Can anyone give me a hint? 1k thanks
73,
Arturo
21 Replies 21
This is a real limit of the CCA, with version 3 maybe things will get better! CCA Is too rigid; should still accept/tollerate the changes made by CLI also because, obviously, are made to speedup provisioning or activate functions not provided by the CCA.
I think I will have to return to the factory cfg because is now in the loop on the dialplan (30 minutes and still not show the dialplan)!!!
73,
Arturo.
I was also getting this error message
Trying to use Cisco Configuration Assistance to work on a UC560.
As soon as I change the enable password to match the Username/Password;   I was able to open up CCA.
Hope this helps some one else!!
Steven DiStefano
Yes, you do.
I hope you are not too dissatisfied that we dont support CLI configured systems.  We used to maintain an out of band configuration guide which used to show partners how to steer clear of what CCA wanted to reserve and interpret a certain way, but that didnt work out well, because there are TOO MANY knobs to tune on UC500 and because frankly most ignored it :-)
We have to come to a point where your costs and our costs of sustaining your practice in hybrid mode is just unrealistic.
I think you will like CCA 2.2.5.  I really do.  I think if you look at the feature reference guide (updated last week) of what we can do with 2.2.5 and try it, you will 'come home to CCA"
On that note, I am going home now ;-)
Good return at home, I go now to sleep ... I agree with what you say but could open a nice thread to discuss this...
73,
Arturo
patrick.hurley
Level 3
Level 3
I had the same problem and as soon as I changed the username password and the enable password to be the same it worked.  Creepy.
Hello ,Im having the same issue
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
i was able to use cca  couple days ago and now its just stoped working
and im still able to telnet to it
any ideas ?
Anyone find a fix for that, ???
