550
Highlighted
Failed to authenticate with the device UC 540
Hello , I have UC540 and couple days ago everything was fine but today im getting failed to authentica error when using CCA
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
i was able to use cca  couple days ago and now its just stoped working
and im still able to telnet to it using TeraTerm or windows cmd
any ideas ?
1 ACCEPTED SOLUTION
Highlighted
Rising star
Hi Arsen,
Just delete the connection you have made in CCA and re-create a new one, sometimes the profile that is first made goes bad and you need to delete it and recreate it.
If you have a screen shot of the error as well, that may be a more of an indicator then me just guessing what the actual problem is.
Give that a try
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
1 REPLY 1
Highlighted
Rising star
Hi Arsen,
Give that a try
Cheers,
David.
