11-01-2010 08:21 AM - edited 03-21-2019 03:13 AM
Hello, I have a uc520 with 15 users and one standalone fax.
I´ve generated several extensions for fax which are all forwarded to the standalone fax 901.That works ...
Now I want to configure the following User Chris with the extension 100 and his own fax-extension 101
should get his fax in chris@test.com.
In the same way it should work for Sarah with the extension 210, the fax-extension 201 and the
email-account sarah@test.com.
Each of the 15 users got a fax-extension xx1and there should be the possibility to print the fax to the
real fax-extension 901.
The UC520 is located in Germany and i use ISDN with three BRIs and there are no FXO-Ports.
The standalone fax is connected to FXS 0/0/0.
I found many How-Tos, but no example to do this with multiple fax-extensions and no FXO-ports.
Any ideas for a solution?
In the first step I thought it would be good to create a mailbox for every fax-extension xx1 and make
them fax-enabled.
Is this the right way or a dead-end?
Kind regards, DetNit
11-02-2010 06:34 AM
