05-24-2011 06:10 AM - edited 03-21-2019 04:08 AM
We have successfully set up Fax to Email using a UC540-FXO solution using just the CCA. We will have a customer with a UC560-T1E1-K9 and they will be deciding whether to receive faxes using a PRI/DID or FXO line. Does the CCA support the fax to email setup using a PRI for faxes?
Solved! Go to Solution.
05-24-2011 07:18 AM
Yes, you can use CCA to configure fax to email using either an FXO or PRI line.
Thank you,
Darren
05-24-2011 07:18 AM
Thank you,
Darren
05-24-2011 08:10 AM
