Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
528
Beginner
Feature Access Codes for IP phones
Hi All,
I'm having a small configuration issue with my uc540. I am trying to use the feature access code to enable/disable night service but I can't seem to get feature access codes working on my 7941 phones at all. Is there somewhere in CCA that I can enable this?
Chris
1 REPLY 1
Hi Chris,
Yo may try to use another code which is not overlapping with the standard ones e.g. *222
Below are the standard ones:
telephony-service fac standard
  callfwd all **1
  callfwd cancel **2
  pickup local **3
  pickup group **4
  pickup direct **5
  park **6
  dnd **7
  redial **8
  voicemail **9
  ephone-hunt join *3
  ephone-hunt cancel #3
  ephone-hunt hlog *4
  ephone-hunt hlog-phone *5
  trnsfvm *6
HTH,
Alex
*Please rate helpful posts
