Features in BE-3000
Adrian Rincon
Dear experts!
Lately I have been discussing the BE-3k with some potential customers and other Cisco distributors, and there has been some questioning regarding some features which I have not been able to find in the documentation. Such features are:
- Support for Forced Authorization Codes (FAC)
- Integration of the Outlook personal contacts for the users
- Support of E1 R2 at the remote sites through a ISR2901
Does anybody have information regarding the above and/or any existing roadmap?
Thank you very much in advance, and please have my best regards,
Adrian Rincon
sanjsinh
Hi Adrian
FAC is not supported. It is on the roadmap
OL Personal contact integration is not supported. It is also not on the roadmap
E1-R2 is natively supported on BE3000.  We have not done solution testing with ISR2901 integration.
Hello Sanjay!
Thank you very much for your kind answers! Excellent, upon that I now can build workaround scenarios for interested customers with such requirements.
Truly,
Adrian
Hi Sanjay,
Is SRST and hot standby on the roadmap? if so when?
Aamir
SRST with PRI interface will be supported in 8.6.5.
Hot Standby is on the roadmap, but there is no committed release yet.
