12-18-2012 06:54 AM - edited 03-21-2019 06:45 AM
Can the Cisco Business Edition 3000 support a Factional T1?
Customer uses Integrated Access Device and only 12 B-Channels are enabled on the T1.
Using CUCM and MGCP controlled PRI, Fractional T1 is not supported. However, we are able to busy out DS0 channels on up to 5 T1 circuits.
Can we do similar on the BE3000 ?
12-18-2012 06:59 AM
Wrong forum, post in "small business voice -CUCMBE3000". You can move you post using the actions panel on the right.
12-18-2012 08:24 AM
Hi Kris,
Fractional T1 is supported on BE3K
Sanjay
