FW 8.5.4: DisplayName Length
we use firmware 8.5.4 for your Cisco SPA 504G and 509G devices.
When I call somebody intern your asterisk set the DisplayName line: "To: Name of Called Person"
This line will be cut on the SPA 509G devices now.
On 504G with only has BLF on the right sight the display shows me, more than 20 caracters.
On 509G with left and right BLF the display shows me, 16 caracters + "." dot
This behaviour is new. On older firmwares the 509G shows 20 caracters too.
Was there a change on font or the distance between the caracters?
Is there a parameter to change this behaviour?
Thank you very much.
      Benjamin Hagemann
0 Replies 0
