Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
864
finalconnect
Participant
FXO ports on UC520 dropping incoming calls
Anybody out there have any FXO teaks (US / carrier AT&T) to help eliminate
incoming FXO calls being disconnected by UC500 during answer transfer to auto at
tend extension?
Example:
voice-port 0/1/0
connection plar opx 602
caller-id enable
602 is the auto attend.
1 ACCEPTED SOLUTION
David Trad
Rising star
Hi Michael,
If you have CLI access, can you please provide some Debug information please...I.E
debug vpm signal
debug voip dialpeer
debug ccsip message
Dont forget to turn on terminal motoring "term mon" when doing teh debugs.
If you can capture this info it would be much appreciated.
Also can you please post your configuration file with all sensative information removed.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
1 REPLY 1
David Trad
Rising star
Hi Michael,
debug vpm signal
debug voip dialpeer
debug ccsip message
Cheers,
David.
