06-07-2010 04:37 PM - edited 03-21-2019 02:39 AM
Is it possible to create pstn trunk groups and use them to specify what extensions call out which fxo ports?
example: extension range 100 places an outbound call which uses any of the ports 0/1/0 - 0/1/3
extension range 200 places an outbound call which uses any of the ports 0/2/0 - 0/2/3
06-07-2010 05:27 PM
Hi there,
There could potentially be more then one way to do this, one of them could be the following:
A caution though, since I have not done this yet I am unsure as to how many Dial-peers the system can handle, maybe if you were to trim them right down to only essential dial-peers, you could have quite a few groups, but i would imagine too many of them will starve the system of resources.
The other possible method is to run Trunk Line Monitoring:
The UC-500 is not good at partitioning, it is not a feature set of the system, the above are work around's and be assured they are not without draw backs, they are also CLI based configuration I am not sure if this could even be done in CCA, further to that I am notoriously bad at following OOB guide lines
Let me know if you require further info on how to do this.
Cheers,
David.
