FXS/Analog phone auto-dial when picked up?
Jeff Cooper
Hello.  UC540 862.  I have a door intercom i have patched into the phone system via FXS port (will not use FXO).  When the button is pressed on the door intercom, you get a dial tone over the speaker and the FXS port is open.   Is there a method to have it auto-dial an extension?   I've setup lobby phones that intercom a specific phone internally, but in this case, i need it to autodial a main hunt group- ext 101, which blasts 4 people.  Unfortunately the door unit does not have a dial-pad.
Thanks in advance.
You did not specify if you are using the voice port in SCCP mode (UC500 default), or not.
For SCCP mode, configure intercom under ephone-dn.
Otherwise, configure connection plar under voice-port.
6 Replies 6
paolo bevilacqua
ephone-dn xx
intercom
to verify per my question, i can use in the intercom command above as any extension on the phone system without any intercom related configuration on the target extensions
so as above :
intercom 101 will ring the call-blast group
thanks
You can use any valid destination you desire.
Please remember to rate useful posts clicking on the star below.
didn't work but again - fxs port as it's not compatible with fxo port ..  (below readout).. trying connection plar 101.. maybe that'll work
KMK-UC540(config-voiceport)#do show voice port sum
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxs-ls      up    dorm on-hook  idle     y
KMK-UC540(config-voiceport)#voice-port 0/0/0
KMK-UC540(config-voiceport)#intercom 101
% Invalid input detected at '^' marker.
KMK-UC540(config-voiceport)#int ?
% Unrecognized command
both ways worked great
thank you!
