05-14-2012 06:21 AM - edited 03-21-2019 05:47 AM
We have had 2 customers whose FXS ports do not get dial tone after the upgrade to 2.2.2.
We do have a STAC case open, but wanted to see if anyone else has seen this issue.
At this point TAC is recommending we load a special firmware image to do FXS/O port testing, and RMA the system if it comes back as bad.
TAC claims to have not seen any other cases like this -- though it seems extremely unlikely that we had 2 FXS ports "fail" at the same time, during the same firmware upgrade -- a software bug seems a lot more likely.
For Cisco Employees: SR # 621650873
Thanks.
11-28-2012 05:25 PM
I'll try your suggestion.
I also made an error in replying to this thread as I upgraded to 2.3.2 (6)
12-12-2012 08:26 AM
Tested the other ports but similar results. I logged an support call a week ago for this issue but it seems to be taking an eternity to get any technical feedback apparently the support engineer is "waiting on the developers to tell me what path to take next" - not sure what will come first the long awaited cordless handset which would negate the need to use the FXS port or some path forward to fix the issue.
12-12-2012 08:35 AM
Hi Stephen,
Sorry for the delay. I have reached the support engineer and he will RMA the box for you as soon as possible.
Best regards,
Wendy
12-12-2012 08:41 AM
Wow Wendy nice work! I wasn't expecting such a quick response (12:40AM here)
12-14-2012 03:15 AM
Well both units have been RMA'ed, replaced them an uploaded saved Config and the FXS port works perfect...
So there it is not a Config issue more like firmware issue...
