Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
610
jcarter
Enthusiast
FXS Ports Registering With SIP Provider
I tried to turn off registration on the FXS ports but they are still registering with the SIP provider.
ephone-dn  17  dual-line
number 301 no-reg both
label 301
description 301
name 301
They are not user phones so they do not show up as ephones if that matters.
Is there another place to turn registration off?
1 ACCEPTED SOLUTION
Ryan Hardy
Enthusiast
If you are using the Voice Port/Dial Peer setup for the FXS, you disable the registration on the Dial-Peer.
voice-port 0/0/1
station-id number 121
caller-id enable
dial-peer voice 121 pots
description Domestic Fax
destination-pattern 121
port 0/0/1
no sip-register
2 REPLIES 2
Ryan Hardy
Enthusiast
voice-port 0/0/1
caller-id enable
port 0/0/1
no sip-register
Perfect
