FXS straight to voicemail
saftool72
Beginner
Beginner
I connected a fax machine to the FXS port which is enabled and assigned extension 25 to it.  When I dial from outside (I have an inbound calling route from fax number to this extension) I get straight to voice mail.  Also when I dial the extension 25 locally I get voice mail and call never goes to the fax machine.  What is the problem?
Alaeddin
Christopher Edgeworth
Frequent Contributor
Hi Alaeddin,
Are you running 2.1.4 or higher firmware?
Chris
After update it is working.  Lets ope it doesnt break after 2.2.2   Thanks for help Chris.
Hello Saf and All.
I have a problem and I need urgent help.
Am using E1 terminated on my UC 560 router. I have finished configurations. I can make calls out through my FXS port but no calls are getting through to me. I tried calling my number but it wont go through. I think I got something wrong in my configuration. Please can anyone help me?
Nelson,
Can you open a new discussion on the UC500 community on this issue?
Does the E1 controller and interface show up and active? Is the E1 a PRI?
Randy
Recognize Your Peers
