Grayfields Deployment behind Juniper SRX100
Stephen Wyndham
Having issues getting SIP working . I setup using SMART designs, but still have an issue. The network topology is voice routing only. The LAN side of the UC320 is working well for both wireless/LAN 192.168.0.0 and VOIP 10.1.1.0.
I have set the WAN port up with 10.1.2.2/30 with a gateway 10.1.2.1/30 and the ISPs DNS. Using the in built ping test I can ping both IP addresses and FQDN so there is connectivity, but the SIPs wont register. The debug log
Nov 29 10:18:49 UC320W user.debug voice: [5]RegFail. Retry in 30
Nov 29 10:18:49 UC320W user.debug voice: RSE_DEBUG: getting alternate from domain:sip.wa.iinet.net.au
Nov 29 10:18:49 UC320W user.debug voice: [6]RegFail. Retry in 30
Nov 29 10:18:59 UC320W user.debug voice: received discard:6f7ffd7f, 20000 from:101010a:6061
Nov 29 10:19:04 UC320W user.debug voice: RSE_DEBUG: getting alternate from domain:sip.wa.iinet.net.au
Nov 29 10:19:15 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Nov 29 10:19:18 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Nov 29 10:19:21 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Nov 29 10:19:22 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Nov 29 10:19:29 UC320W user.debug voice: received discard:17f9705f, 20000 from:101010a:6061
Nov 29 10:19:36 UC320W user.debug voice: RSE_DEBUG: getting alternate from domain:sip.wa.iinet.net.au
Nov 29 10:19:36 UC320W user.debug voice: [5]RegFail. Retry in 30
Nov 29 10:19:36 UC320W user.debug voice: [6]RegFail. Retry in 30
The UC320 work when directly connected to the internet.  Any tips would be great
Hi Stephen,
I see you are using a private address for the WAN of the UC320W.  Under Status -> Support Tools -> Logs enable SIP logs for your SIP trunk.  You may have to wait a few minutes but you should see an outgoing SIP REGISTER message and hopefully some sort of response to the REGISTER message.  If not, suggest looking at the edge router to see if you have SIP ALG enabled or there are any SIP logs being generated on that device.
You could also try enabling NAT keepalive on the SIP trunk page of the UC320W.
Hope this helps.
Chris
wenyang
Level 4
Level 4
Hi Stephen,
The registration failed. You may want to turn on the debugs at gateway to find out the reason.
Wendy
Hi Stephen,
Hope this helps.
Chris
