Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
665
Andrez Chavez
Beginner
Greyfield Deployment of UC320w with RV220W
Having issues getting UC320 deploymed behind RV220W. I setup using SMART designs, but still have an issue, unable to get UC320 on the network.
Here is my setup:
RV220W
WAN - Static IP to ISP
LAN
VLAN 1
Inter VLAN Routing - enabled
device management - enabled
port 1 - untagged
port 2 - untagged
port 3 - untagged
port 4 - tagged
LAN IP - 10.0.0.1/255.255.255.0
DHCP - enabled
DHCP - address range (10.0.0.150 - 10.0.0.254)
VLAN 4
Inter VLAN Routing - disabled
port 1 - tagged
port 2 - tagged
port 3 - tagged
port 4 - untagged
DHCP - disabled
IP - 192.168.2.253/255.255.255.252
UC320
UC320 WAN connected to LAN Port 4 of RV220W
Setup to Route Voice Only
IP - 10.0.0.2/255.255.255.0
GW - 10.0.0.1
PC connected to Port 1 of UC320
Unable to get IP on PC connect to Port 1 of UC320
Unable to access IP 10.0.0.2 of UC320
1 REPLY 1
janickle
Beginner
Hi Andrez,
The UC320W only has 2 VLAN’s.  VLAN 1 is the data VLAN and is untagged.  VLAN 100 is the voice VLAN and is tagged.  If you are connecting the UC320W to your RV220W you need to make sure that the RV has both VLAN 1 and VLAN 100 configured on it.  On the RV220W configure the port for 1 untagged and 100 tagged.  You can still configure the UC320W for a voice only deployment.  This should resolve the issues you are seeing.
Thank you,
Jason Nickle
