Guest wireless network associated with VLan 60 allows guests access to our network
Barry McKinley
Beginner
Beginner
We setup a Wireless Guest network to allow visitors access to the internet. Guests are assigned an IP address in a different subnet.
Today it was discovered that guests had access to our LAN via the Guest wireless network. I am not sure what has changed. The AP541n configuration looks as it did when the Guest network was configured. The entries for Guest and VLan60 appear to be the same when configured to two earlier documents containing Sho Run information.
What could cause the wireless to now have access to our company LAN and a different IP subnet.
Barry
mcasimirc63
Enthusiast
Enthusiast
This is normal behavior if you don't have an ACL blocking Inter-Vlan routing on certain interfaces. What is the subnet of the Vlan 60 and what is the Vlan and  subnet of the Corp Vlan?
Hello Marcus,
The subnet of VLan 60 is 172.16.37.0
The corporate VLan is VLan 90. The subnet is 10.42.5.0
I see the following entries;
access-list 107 deny   ip 172.16.0.0 0.15.255.255 any
ip dhcp excluded-address 172.16.37.1 172.16.37.100
ip dhcp pool GUEST_WIRELESS
   network 172.16.37.0 255.255.255.0
   default-router 172.16.37.2
   dns-server 10.42.5.21 10.42.5.22
   domain-name rittalguest.com
Should the Guest Wireless use our internal DNS servers? Shouldn't it be something like 4.2.2.2?
Thanks for the help,
Barry
Recognize Your Peers
