11-25-2009 05:01 AM - edited 03-21-2019 01:49 AM
Hi Everone,
Has anyone tested a Plantronics headset with the new SPA504G ??? if so which one works or does anyone know of a compatable headset with these new SPA5XX IP Phones.
Many Thanks
J
12-04-2009 12:31 PM
Maybe the Plantronics website can help you. Click here or you can click here to check out what we have posted regarding Plantronic headsets in the Small Business Support community.
Cindy Toy
Cisco Small Business Support Community Manager
www.cisco.com/go/smallbizsupport
08-29-2011 02:43 PM
08-29-2011 02:58 PM
Hi James,
It depends on what you want, but what has been tested to work and I know work with the SPA-500 range is as follows:
Wireless:
I have not been able to test any of the other wireless ranges, basically we only ever buy what the customer can afford and they are the cheapest ones without blowing a budget.
Corded Headsets:
If you want slightly cheaper headsets then the Jabra Corded headsets are normally about 10% cheaper (Well in my neck of the woods) but the Wireless CS60 is the most popular, the only issue is you might have problems getting it to work with the SPA-500S module if you put one on it, I am having great difficulties with that right now, but I am sure I will find a way around it.
Hope this info helps you out.
Cheers,
David.
02-13-2012 07:42 AM
I am not sure if you found what you are looking for but these headsets from Acoustical innovations work very well and are a bit less expensive.
www.aiheadsets.com/cisco-spa-headset.html
For what it's worth.
04-02-2012 12:28 PM
We are going to order a few of these http://www.aiheadsets.com/LX-900-25.html
anyone else using them?
