Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
537
Beginner
HELP: UC520 and CCA
I am having an issue getting the IP address to connect to CCA.  Anyone know how to get the IP address for CCA?
1 ACCEPTED SOLUTION
Advocate
Re: HELP: UC520 and CCA
Use serial console to configure IP.
According login credentials - read password for uc500
4 REPLIES 4
Advocate
Your LAN administrator knows what IP address can be used in your network. So ask them, he will assign a free one to you.
Beginner
I got this router on eBay a few months ago.  I had to factory reset it.  I am having issues finding the ip username and password for CCA.
Advocate
Highlighted
Beginner
this is old.  I found out how to do it.  Thank you.
