07-09-2012 10:42 PM - edited 03-21-2019 06:01 AM
My night is not going well. I recently purchased a used uc520w from eBay for my office. Im trying to have the best for my new dream place, but this is something that has saddened my mood. I plugged everything in right. It powered up but then after a few seconds the Power Over Ethernet ports lights turn off and the only lights that remain on are the LED for SYS and POE. I really was excited about this and have already bought the ip phones to go with it. PLEASE PLEASE someone help me get it working. CCA doesn't recognize it nor do I get an IP address from it when my computer is plugged directly to it. I have googed til im blue in the face. Please let me know. Thanks for any advice.
07-10-2012 02:37 AM
You need to connect a via serial console first. From there you will handle it exactly the same as a non-booting router, for which there is an abundant documentation anywhere.
Note however the UC500 is not end-user friendly (and more so when in boot failure), so if you want sure, professional results the best way is to hire someone with certification or equivalent experience.
07-18-2012 12:00 PM
Just to echo what Paolo said, I would strongly recommend anyone interested in the 500 series to go through a professional to help them set it up. We have a great deal of experience in the telecommunications industry, and we bought what I would call a "gray market" unit without any professional services. We eventually gave up and sought out help, even trying to do a straightforward CCA-only install. It is a nice system and pretty straightforward to set up (our problem was solved by a software update) but still can be tricky.
Grab a serial cable and plug in to a local PC from the supervisors/priviledged port on the 500 series. The one that came with our 560 was colored baby blue, if you happened to get one in your package. Plug that into a PC, I believe the defaults are 9600 8n1 or 19200 8n1, and you should see details on what's going on during the boot. Hopefully nothing too bad.
