03-10-2011 12:47 PM - edited 03-21-2019 03:47 AM
Hey guys,
I've been trying to figure out exactly the right way to modify the CLI on my UC520 to allow for a pause in the midst of a dialing string. In our example, the line that the UC520 is trying to pick up does not present a dialtone immediately, and therefore often misses the first digit or two that is sent from UC520. The line access code is "8", and it is for international dialing only. Currently, the rule is matched when the user dials 80015555555555 - essentially 8 + 001 + area code + number. The UC520 shoots a string of digits and the line is sometimes not even off hook when the string of digits begins. Therefore, I would like the UC520 to pause between the 8 and the 001.
I have done a bunch of searching, and it looks like I want to add a "," to the dialing translation rule, but I'm unsure of which rule to add it to. This pause should be added to all calls that are placed when a leading "8" is dialed. Here are the rules to choose from:
voice translation-rule 410
rule 1 /^7\(.*\)/ /\1/
rule 2 /^9\(.*\)/ /\1/
rule 3 /^8\(.*\)/ /\1/
rule 15 /^...$/ /4067551721/
voice translation-rule 411
rule 1 /^7\(.*\)/ /ABCD7\1/
rule 2 /^9\(.*\)/ /ABCD9\1/
rule 3 /^8\(.*\)/ /ABCD8\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
rule 2 /^7/ //
rule 3 /^8/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
Thanks in advance!
Seth
03-10-2011 06:38 PM
Hi Seth,
I had this very issue when running a GSM gateway on the UC-520, but if my memory has not faded and it is, this was done on a Dial-Peer level not the translation rule level, in other words when the out-bound call was triggered and it hit that specific DP the pause was introduced to allow the GSM gateway time to get going.
However though I cant remember right now how to implement this, I will dig through some of my old configuration guides that I write up and see if I did keep it, and if I did I will post it up for you
Cheers,
David.
03-14-2011 08:52 AM
Try adding a comma where you need the pause in the destination-pattern of the dial-peer. You could try a comma in the translation-rule, but I'm not sure if it will work
Adam Compton
03-14-2011 09:58 AM
Hey guys,
This is the dial-peer that I found that I believe should be correct:
dial-peer voice 66 pots
trunkgroup Iridium
corlist outgoing call-international
description **CCA*USACEMCV*International**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 6001T
forward-digits all
no sip-register
I modified it by entering the following commands:
USACE_MCV1_UC540W(config)#dial-peer voice 66 pots
USACE_MCV1_UC540W(config-dial-peer)#no destination-pattern 6001T
USACE_MCV1_UC540W(config-dial-peer)#destination-pattern 6,001T
USACE_MCV1_UC540W(config-dial-peer)#exit
USACE_MCV1_UC540W(config)#exit
At first it seemed to break it completely - i.e. the UC540 would give me a busy as soon as it reached the second number in the sequence. I then reverted back:
USACE_MCV1_UC540W(config-dial-peer)#no destination-pattern 6,001T
USACE_MCV1_UC540W(config-dial-peer)#destination-pattern 6001T
This, however, did not work. All outbound calls by dialing the prefix "6" wouldn't even get out to the Iridium phone.
Thankfully, I hadn't saved and was able to reload.
Did I make a mistake in the above?
Seth
03-14-2011 11:06 AM
Try this:
trunkgroup Iridium
preference 5
forward-digits all
no sip-register
prefix ,
Adam Compton
03-14-2011 11:28 AM
Hi Adam,
Can you clarify that this rule that you recommended places the pause between the 6 and the 001? 6 is the line selection prefix, so it will need to go after the line has been picked up to give the device the chance to go off hook. The UC540 should then pause, then send the 001... digits through to the Satellite phone.
The reason I ask, is that the offending unit is remote to me, and I'm testing this with a system that works fine even without the pause. This rule doesn't seem to affect our success (i.e. the dialing out still works), I just want to be sure that this rule should do what I have described above before I say that this is the correct answer.
Thanks for your help,
Seth
